Author Topic: Resistor Test problems Fluke 75 Series II  (Read 678 times)
Offline kdl1950Topic starter
« on: July 12, 2024, 05:50:28 pm »
Hello everyone, I have a problem again.
This time with a Fluke 75.
The error lies in the fact that a value of 0.00 ohms is not possible when measuring the resistance.
If the input is short-circuited, the measuring device starts at approx. 20 ohms and runs to a final value of 1.2 ohms in approx. 1 minute. (see pictures).
I have already tested internally without the connection socket. Same error pattern.
Thus the bushings can be excluded. The cable is new and tested on other measuring devices. It looks like a capacitor is changing?!?! :-//
Does anyone have an idea or knows the problem? I checked the various internal resistances. All OK.
What is also noticeable is a similar problem with the diode/continuity test.
It takes a certain amount of time until the value approaches 0.00.
It won't be quite 0 either.
Continuity testing works immediately and has no problems.
Greets from Germany
Offline m k
Re: Resistor Test problems Fluke 75 Series II
« Reply #1 on: July 16, 2024, 04:11:24 pm »
Manual has Schematics.
Get hair dryer and non conducting cold spray can.
Warm up the thing with a hair dryer.
If lower resistance value appears sooner than without the dryer move to the next step.
Learn to shoot cold spray so little that only a single drop comes out.
Put that drop on the suspicious component.
You can also drop it on a single pin.
With luck you find a source that is external.
It can also be a dirty selection wheel.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline steerage250
« Reply #2 on: August 02, 2024, 08:58:35 am »
Any luck solving this?  (I have the same problem - and I don't want to through-away my faithful old Fluke!)
I found a service manual for it on the Fluke website, but the schematic and component layout differ from my circuit board (the differences start immediately at the V/ohms input terminal where the schematic shows it connecting to 2 resistors, whereas mine connects to one resistor and the spark gap device)
« Last Edit: August 02, 2024, 09:36:01 am by steerage250 »
« Reply #3 on: August 02, 2024, 06:17:21 pm »
Hello steerage250,
yes, there are insights and I can make it relatively short.
I found the crucial clue here: "Fluke 77 III Resistance measurement fault"
U1 has a defect or breaks.
I heated the chip properly for a short time using a hot air dryer.
The result is or was that the resistance measurement immediately goes back to 0.00 ohms. Unfortunately the measurement drifts away again after a few days.
You can try it.
The problem is definitely with the chip U1.
I just reheated the chip. Here the result. From 0.02 to 0.00 in about 5 seconds.
It remains to be seen how long the “repair” will last.
At some point even a solid multimeter will reach the end of its life.
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #4 on: August 03, 2024, 01:07:36 am »
Is it any chance that the solder has cracks in it?
If it does not work after re-soldering, then give up :palm:
