Hi all,
I recently repaired an hp 3478A I got off of ebay and I have noticed that the 3V range is around 0.4V less than what it should be. I have measured the signal going to the ADC and it appears to have the normal 0-5V (should be 0-10V according to the manual but that is what I measured) signal present like all the other ranges. This makes me think that the input circuitry is fine, but I have no idea how the ADC could be inaccurate on a single range since the same 0-5V signal is going into the ADC on all DC ranges. I personally think it could be a calibration issue, but I am hesitant to erase a possibly perfectly good calibration. Does anyone know what could cause this issue or should I just try to recalibrate it? Also before anyone asks, the power rail voltages are fine and the majority of the supply caps have been replaced.
Thanks!
