I tried soldering the solder wick wire, but solder doesn't adhere to the substrate. Can i solder a wire to the trace and run it through a corner of the chip and then solder directly to the pin by routing it on the top of the chip? I would glue the wire down to the pcb underneath the chip to avoid unwanted contacts.
