Hello everyone,
I have an Oscilloscope Agilent DSO1004A, channel 2 behavior is strange. The sinewave appear with a lot of noise
I connected Function Generator 1Khz sinewave directly to channel 2 with BNC to BNC cable. I change the BNC cable and still got the same result, I also connected a different F.G and had the same result all of the other channels are good. I teardown the DSO1004A to do an inspection of the BNC connector to the board, I check continuity it looks good. I'm thinking the connector itself maybe got damaged, Does anyone had something similar? Do you have any tips how should I proceed.
Thank you very much.
