I tested everything from the top side ie all capacitors, mosfet, resistors etc. Everything was found ok except optocoupler. The smps stopped to work after a storm thunder ⚡⚡⚡.
All smd resistors from the back side seems to be also ok, so I suspect the pwm driver...
