Thanks to gamalot info, got the resistor replaced as well as some other components in its the failed area and all works, but the output rail voltages appear to vary from nominal by around +/- 0.4 volts, without a manual for the power supply, unsure if this is acceptable.
Also any idea if what VR501 controls. Thanks.
