Watched most of the video. It's a bit hard to see exactly the problem. Some of what's shown looks like the contrast is set too high. Some may be failure to erase properly. When I erase an LCD, I print every pixel with a 0. There are possibly other causes.
Can you post a picture of your LCD to clarify exactly what the problem is?
