Please, see below the problem with our equipment Anritsu 37269E
Sheeva PLug is single board computer used as file server for 37269E VNA.
It´s connect the instrument to ethernet and also the USB hub and store the OS.
Our problem was the BBRAM batery foult cousing boot data lost.
Attached you see the batery that was changed but there is no way to recovery data.
Apreciate your help,
Regards,
Geraldo César Simão
