yes i was going to give up and started searching on internet for replacement sensor, but then i removed coating and measured one of the capacitors as short i checked on the other there wasnt short. it was a 10nf one which i replaced i didn't think it will work but i assembled it and tried to zero it and to my surprise it worked ....
i made vacuum to check accuracy and it was working ok i don't know what to think of this repair, extreme luck.
