Greetings EEVBees:
--If you have a DMM and can solder, you can get some good things for your, family or friends, or even make a dollar or two, with just a little effort. I badly need a good fan, so I was pleasantly surprised to see this Sharper Image SI868 Electronic Spire Fan by the side of the road. It is very clean, and almost no dust build up on the inside, which indicates that it became inoperable a while ago and has been sitting in a closet somewhere for lo these many years. Amazon lists these, used, for $100 or so. Motor works when hooked up to 120V. So I spudged the long front panel off, and from there it was easy to get to and desolder the button board and the control board. Button board checked out OK. Below are the contemporaneous notes, and pictures I made when checking the components. As you can see the culprit would seem to be the 6.1 Volts, 1 Amp Zener. I have ordered 3 of same only at 1.3 Amps from DigiKey for a total of $3.44 shipping included, and will report back after installation. And, as per usual, I have replaced the no name caps with name brands at 105C and 25V. I can almost feel that ionized breeze already, I had better have my straw hat, hammock, and cool libations at the ready.
Sharper Image SI868 Electronic Spire Fan - Made in April 2003
Name Brand Temp Value Volts ESRin ESRout Cond. ESR of NEW
C4 JAKEC 105 470 16 0.12 0.10 0.02
C5 JAKEC 105 470 16 0.09 0.10
C6 CDIIO 85 47 16 0.14 0.86 0.16
20 Pin Dip Chip SC8207A4KS Fan Remote Control Decoder has no shorts, and fan can be operated without it in any case.
Fuse 1A Good
T1,T2,T3,T4,T5 - MAC97 A6 PHL2N Triacs All Good
D1, D2 Good
D3 - 1N4733A 6.1 Volt, 1 Amp Zener Diode is completely open - Blown - Eureka!!!
--Sorry about the justification of the text, but SMF makes complete mincemeat of any attempt to copy in columnated text.
"During times of universal deceit, telling the truth becomes a revolutionary act."
Eric Arthur Blair - George Orwell 1903 -1950
Best Regards
Clear Ether
