Hi all,
I'm trying to repair a pcb and would appreciate some help trying to identify a transformer part. The board drives a 24V DC fan, the fan output was obstructed and this seems to have damaged the board. I have identified that the transformer has a valid voltage at the input but nothing on the output so I'm assuming it has been damaged.
From what I have discovered so far the pcb takes 240V AC, has some form of rectifier which results in 150V DC going into the transformer. The transformer has two outputs, 24V DC and possibly 5V.
The only marking on the part is a label "3302-0010-01a" which doesn't seem to yield anything on google. Looking at the yellow colour I'm thinking it maybe a Wurth part as these all seem to have this yellow wrapping.
Any help appreciated.
