My Hioki 3001 was made in Japan many years ago, and has survived well. I have had a few oops moments with it, and have a box of spare fuses next to the battery ( 6.3x32 glass 1A fuses) for those moments. Had to fix resistance ranges when accidentally applied 12V and cremated a resistor. Accuracy is still very good, all DC voltage ranges work to spec and AC is as good as it can be, off under 10% of FS because of the diode rectifier, and current and resistance are within 5% which is in spec. I have had this for over 30 years now.
