This chip have the paths a little baked.
Here you go:it's a AOP610.http://aosmd.com/pdfs/datasheet/AOP610.pdf
This is normal, those mosfets run quiet hot and with time PCB darkens in most of the monitors.
Quote from: TheBay on September 12, 2016, 08:59:14 pmHere you go:it's a AOP610.http://aosmd.com/pdfs/datasheet/AOP610.pdfThanks @TheBay. I Will save that and test this chip before i put everything together. Weird, i couldn't find the brand.Quote from: wraper on September 12, 2016, 09:05:49 pmThis is normal, those mosfets run quiet hot and with time PCB darkens in most of the monitors.Probably should change that IC before burnout. If i can find one similar. Thanks
BTW, if it does not work after replacing the capacitors, check secondary winding of the CCFL transformers, should measure around 1k.
