Author Topic: Repaired - Digitron T208 Thermocouple meter  (Read 4486 times)
Offline tom66Topic starter
« on: August 25, 2012, 08:17:20 pm »
Got it free from work, they give me lots of nice broken stuff.
It had a common LCD issue. Problem was half the segments were not visible, the other half dim or fully visible.
Tore it down - very difficult as it is completely sealed. Had to cut open at the only exposed edge and unbolt the battery hookups (9V) - the connector connects through some bolts. I guess it is designed for factory environments with a lot of dust and particulates, or maybe even brief submersion? I did not care about that, I just wanted a nice accurate thermocouple meter.
So, I tore it down to reveal the circuit board. Immediately, I saw the problem: the zebra strips were bent. I loosened the LCD bolts, reseated the zebra strips, and that fixed it.
Second issue was I had no thermocouples with the standardised connector. I -did- have one with banana plugs. So I cut the leads off, and soldered them to the PCB.
Free, very high accuracy thermocouple meter. Lots of uses for this one - will replace my IR thermometer for most uses.
Suspect the OEM to be "AET", unit is made in England.
