Dump the EDID info from the VGA and HDMI ports and decode it. The monitor doesn't even need to be powered up to do this.
You could hook up a laptop to the monitor and allow it to detect and store the EDID in the registry. You could then examine the Windows registry, export the EDID and analyse it with an appropriate tool.
The EDID for my monitor is here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\DISPLAY\AOCA781\1&8713bca&0&UID0\Device Parameters
This is the data:
"EDID"=hex:00,ff,ff,ff,ff,ff,ff,00,05,e3,81,a7,b8,8a,00,00,16,0e,01,03,68,22,\
1b,78,2a,a6,9c,a1,5a,4b,98,24,16,4c,57,bf,ef,00,81,80,01,01,01,01,01,01,01,\
01,01,01,01,01,01,01,30,2a,00,98,51,00,2a,40,30,70,13,00,78,2d,11,00,00,1e,\
00,00,00,ff,00,30,38,30,34,35,4a,41,30,33,35,35,31,32,00,00,00,fd,00,37,4b,\
1e,53,0e,00,0a,20,20,20,20,20,20,00,00,00,fc,00,4c,4d,37,32,30,2f,4c,4d,37,\
32,30,41,0a,00,fa
