Thanks guys,
This unit was stored in an un-heated warehouse for several years, it was bagged and boxed but I suspect it was exposed to low-ish temperatures as low as +3 or +5, but probably not below freezing. (Ireland rarely experiances sub-zero temps for long)..
I'm planning to open it up and inspect the LCD, but I suspect the display is a sealed unit and can't be torn appart??
what do you think?
Tracker
