Author Topic: [Solved] Repair / LA-6847P Rev : 1.0 / Shorted  (Read 5236 times)
Offline xanTopic starter
« on: August 09, 2018, 10:10:28 am »
Hi Everyone!
Back again this time with LA-6847P board, it's from a toshiba nb and won't power on  it comes with a power adapter 19v / 4,74A and notebook is working with nominal 19v / 3,95A. I just recover it with a new Si4483ADY (PQ8) like the shorted one before... and a new polifuse on B+ line (PF2) but after 1 sec after connected to the adapter, a small whistle come from it and back again with Si4483ADY shorted like before  |O could you help find witch section is shorted and give it a new life  :-/O. Below schematics and datasheet, i will provide some measurements after but it's so hurting if i remove shorted mosfet 19v is stable but i can't measure so much more on the board instead if the component it's on the board adapter goes on under protection mode and stop regulating power, same with battery pack..
Thank's
« Last Edit: August 29, 2018, 09:11:10 pm by xan »
Re: Repair / LA-6847P Rev : 1.0 / Shorted
« Reply #1 on: August 09, 2018, 01:16:33 pm »
below 1st results.
Offline Rasz
    • My random blog.
« Reply #2 on: August 09, 2018, 04:16:03 pm »
if PQ8 fries there is something bad behind it
« Reply #3 on: August 09, 2018, 04:32:28 pm »
1st) Do You think PQ7 it's safe ? (i just burned it 2 times 350° cause it's nearest..  :-BROKE) did you see continuity values are ok ?
2nd) It could be PF2 (p.43) BATT_S1 or i misunderstood diagram flow ? i think gate voltage about 7.5v on PQ7 it's ok so PACIN flow from PR64 correctly...
3rd) Should i remove PR45 to isolate the two Mosfet and goes on ?
« Last Edit: August 09, 2018, 04:34:04 pm by xan »
Offline Rasz
    • My random blog.
« Reply #4 on: August 09, 2018, 06:10:04 pm »
1 "The definition of insanity is doing the same thing over and over and expecting different results"
2 fixing laptops is not about randomly guessing which component to replace
3 use lab supply with current limit. Dont fix laptops using factory PSU, use a bulb at the very least.
4 remove fried PQ8, measure resistance to ground on B+ and BATT+ points on diagram
5 does it work on battery alone? dont test if you didnt already, it might result in another fried component :)
« Reply #5 on: August 10, 2018, 01:21:26 pm »
(first time another from other lab, second it was me  :palm:)
2 "fixing laptops is not about randomly guessing which component to replace"
^-^ of course
3 "use lab supply with current limit. Dont fix laptops using factory PSU, use a bulb at the very least."
(i'm looking for a good 'cheap' one)
4 "remove fried PQ8, measure resistance to ground on B+ and BATT+ points on diagram "
Desoldered PQ8 resistence to ground 'diode mode' = 0 B+ / BATT+ line taken from 'PC42
10U_1206_25V6M +' to ground 'diode mode' = 0.570 See attachments i have some extra measurements. (i have teste much more things i got 5v on a small resistor 4.7u ..etc, i will write after...)
5 "does it work on battery alone? dont test if you didnt already, it might result in another fried component :)"
(for now PF2 tested on continuity not permit to make more test i need to desolder it again.. should it stay on board ? For now i placed battery pack twice and i get about 10.5v on a side of PF2 .. but nothing else on that line...)
Offline Rasz
    • My random blog.
« Reply #6 on: August 10, 2018, 10:06:27 pm »
so now you know where the problem is
B+ powers everything, now go down the diagram, locate PL11 PL20 PL21 PL801 etc and start pull;ing them one by one and checking which side the short is
« Reply #7 on: August 12, 2018, 12:08:44 am »
thank's hope for the right way! ok all this filter pl10 coil it's ok and pl11/pl19(seems a small coil)/pl20/pl21/pl601/pl801/pl802 all to ground = 0 ... still inpsecting... hope i pulled everything on B+ rail ... the lastest test are for pr45/pq6/pl19/pc73/pc74/pc75/pc23/pc24/pc25/pc26... some of it main rail.
I found pc27 (above pq7 on schematics) and pc28 (above pq8 fried one) both fail continuity to ground = 0 ... (is this making any sense?)
 :-BROKE
anyway for now seems first component to fail continuity = 0 are pc27 and pc28
i will make more measurements tomorrow..... any idea ?
Offline Rasz
    • My random blog.
« Reply #8 on: August 12, 2018, 02:53:45 am »
obviously, you are supposed to pull one side of those coils into the air and check which side is shorted
 :-BROKE
pc27 cant be shorted, unless you managed to fry something in the meantime, it was fine before your second post in the thread
pc28 is 0 to ground because it is sitting on B+
« Reply #9 on: August 12, 2018, 04:33:55 pm »
of course i'm wrong ... my fault pc27 is not shorted!! anyway... i'm swimming around right no... no destination...  :scared: go now still  :bullshit: some more i have power ic voltage above
« Last Edit: August 12, 2018, 04:36:52 pm by xan »
« Reply #10 on: August 13, 2018, 05:11:11 pm »
Do you think all the component on B+ line could be shorted ? i mean all mosfet and some caps ? i have strange readings across all the line...
PQ17 +gd i have at start 550 and after goes to about 1900 and +gs start from 0 and goes to 1300... +drain to source = 550 and reverse 505 this meaning it' fried ? or it's the effect of b+ shorted...
again on PQ6 sitting on B+ it's ok the gate is isolated = gs = gd = (and reverse) = 1  but ds = 550 and sd = 505...
again PQ19 gd = 1 it's ok +gs =  1600 -gs = 450 ... are this test useful to see if a component it's on fail and should be removed? do you experience too ?
(sides of the mb down)
« Last Edit: August 13, 2018, 08:42:29 pm by xan »
Offline Rasz
    • My random blog.
« Reply #11 on: August 13, 2018, 09:49:33 pm »
charging capacitor
« Reply #12 on: August 15, 2018, 03:22:01 pm »
that's right it was caps, i post updated value on schematics attached... i've taken more accurate voltage measurements i need to know from where 0.30 v coming from... maybe it's near the solution.. ^-^
B+ is out of this 0.32v it's around csin csip power IC and batt+ what do you think ? are the value for the power controller on tollerance ? the circle it's coming to the closure! (excluding all the possible damages along the B+)  8)
« Last Edit: August 15, 2018, 03:34:21 pm by xan »
« Reply #13 on: August 17, 2018, 06:00:52 pm »
Here some update, i finally repair with success 1st B+ line, it's not anymore shorted but i dicovered some other shorts along B+ like expected...  but i start test again.. and again... (+VGA_COREP / VGA_CORE / +VTTP )what do you think? could be vga 216-0774009-A11PARK_FCBGA631 - UV1D - PARKR1@ ?? do you experience ? Some suggestion to be quickly?  :horse:
« Reply #14 on: August 17, 2018, 06:05:53 pm »
and here second part  :horse:  :-DMM
Offline Rasz
    • My random blog.
« Reply #15 on: August 18, 2018, 01:54:50 am »
some legend for the colors would be nice
I would venture a guess its fine now, that cap was the sole fault, minus all the things you managed to screw up in the process of "repairing it" :)
« Reply #16 on: August 18, 2018, 07:49:22 pm »
update i cut out all +VTT / +VTTP (p.42 via jumpers pj11 pj13) and next line +1.05v (p.46 via jumper pj20) now only next to +1.05v is on short nothing to repair there.. VTTP / VTT is safe but i have low resistence and then chargin cap.... still measure...  \$\Omega\$ \$\Omega\$
What's that 1.05 used for ??
Here backside PCH core  :blah: :wtf: is that? R? C? 50% of chance! anyway is on short! :-BROKE Could do you help to locate missing component on schematics ?
« Last Edit: August 18, 2018, 09:46:35 pm by xan »
Offline Rasz
    • My random blog.
« Reply #17 on: August 19, 2018, 11:10:42 am »
I really dont understand what you are doing at this point. Yes, low voltage high power rails for GPU and CPU naturally have low resistance, no those are not shorted.
« Reply #18 on: August 19, 2018, 12:19:55 pm »
Ahhh yeah sorry ... i am little bit confused...  :-X??? so.. i will power on the machine  :-/O B+ is safe... but i don't expect machine pass over VALW steps.. Let's do it!  :popcorn:
« Reply #19 on: August 19, 2018, 03:54:24 pm »
 :-DD led light on -> now fan spin on -> 5 seconds.... but like i say no video the system stop itself  :-// any suggestion for inspect GPU_COREP/GPU_CORE, +1.8v, and +1,05vs  :rant: ;) :horse:
keep you updated next!
« Reply #20 on: August 23, 2018, 09:11:22 pm »
Here a little update on voltage (after B+ no more shorted), do you think somethings is wrong on this voltages... ?  :-DMM (see attachment, don't take care about continuity info)
Thank's
Offline Rasz
    • My random blog.
« Reply #21 on: August 23, 2018, 09:28:33 pm »
5V shouldnt be 6V, maybe something wrong with TPS51125 feedback
« Reply #22 on: August 23, 2018, 09:35:05 pm »
ooh sorry.. my fault on png conversion.. it's 5.14v...
(attachment better res values)
« Last Edit: August 23, 2018, 09:37:33 pm by xan »
Offline Rasz
    • My random blog.
« Reply #23 on: August 23, 2018, 09:37:55 pm »
so the problem is not on powerlines
« Reply #24 on: August 23, 2018, 09:41:47 pm »
should i probe testing again voltage during power on pressed, on all of the other jumpers ? PJ101 PJ23 etc etc ... right ?
