Author Topic: Semicon S-219 rectifier diode cross-reference.  (Read 694 times)
Offline nonsuchproTopic starter
    • YouTube
« on: May 11, 2020, 10:06:52 pm »
Hey all!
I need to replace a rectifier diode but coming up short on a data sheet or cross-reference. It's a Semicon S-219 (pics below). A buddy of mine said a 1N4007 should work just fine. I believe him but I figured I would ask you guys what you think I should use.
Thanks in advance!
Offline Evangelopoulos Panagiotis
  • Country: gr
Re: Semicon S-219 rectifier diode cross-reference.
« Reply #1 on: May 14, 2020, 08:11:28 am »
I have no idea if this is even close to what that diode is but it was all could find.
https://datasheetspdf.com/datasheet/1N219.html
The following users thanked this post: nonsuchpro
Online David Hess
  • DavidH
« Reply #2 on: May 14, 2020, 02:11:30 pm »
The only real question is about the current; offhand I do not remember over what current range the "top hat" package was used.  But the chances are that the 1N4007 which is 1 amp will work fine.
I do not think that is correct because it is the wrong package.
