Author Topic: Repair for TDS210  (Read 3779 times)
Offline Orion63Topic starter
  • Country: sg
Repair for TDS210
« on: October 14, 2020, 05:31:52 pm »
Hi, I have had this TEK TDS210 scope for a few years and did not happen to use it for a long time. When I switched it on a few days ago, although I can see faintly that all the functions working on the screen, but the screen itself looks to be fuzzy with some crack like appearance on it from inside. Please refer to the attached pictures. I guess, some issue with the Front Polarizer. Anyone in the forum have any experience in replacing the Polariser ?
Other questions I had was :
1. Whether only the front Polarizer needs to be changed ?
2. What Polarizer is required 0 deg or 90 deg or any other ?
3. Whether the Backlight also needs to be changed ?
Regards
Offline shakalnokturn
Re: Repair for TDS210
« Reply #1 on: October 14, 2020, 07:32:16 pm »
Yes it looks like the front polariser, I've done it before in a TDS 220, unfortunately the polariser I tried was not the right one and gave a low contrast although usable.
If I was to try again today I'd test this one:
https://3dlens.com/linear-polarizer-film-200x250mm-with-adhesive.php
Don't be too disappointed if you test it and it's not great.
Removing the polariser isn't fun, heat and white spirit do help to peel the glue.
CCFL looks OK.
Offline george.b
  • Country: br
« Reply #2 on: October 14, 2020, 07:43:41 pm »
Yes, I have replaced the polarizers on my TDS220 and helped a friend replace the polarizers on his TDS210. Dunno if you've done this before: it's a pain in the ass to do, it stinks, and you have to clean the adhesive residue from the screen. Nail polish remover and an old credit card help a little. Be very careful not to break the screen, nor to rip the flex cable.
Probably not. It seems both polarizers degrade.
My friend bought new 0/90 degree sheets and the result was pretty good. I used old polarizer from a broken LCD monitor and I just rotated the sheets until I was happy. Ended up with a yellowish tint, I'll probably re-do it one of these days.
No, unless you find it's too dim for some reason. Mine was. Instead of replacing the CCFL, I cobbled an LED backlight together.
The following users thanked this post: CharlieD
  • Country: sg
« Reply #3 on: October 15, 2020, 11:41:12 am »
Thanks, for the replies. Anyways, I will try replacing the polarizers first before I buy a new China-Make LCD. I saw a few in the aliexpress. Any recommendations for LCD purchase which has been tested working ?
Offline george.b
  • Country: br
« Reply #4 on: October 15, 2020, 10:35:53 pm »
What I can say is that the later model, made by Nan Ya, seems to look quite better (to me, at least) than the older one made by Sharp.
  • Country: sg
« Reply #5 on: October 19, 2020, 09:51:49 am »
Hi, @george.b and @shakalnokturn, I have taken apart the LCD Display module out from the TDS210 body. May I know which is the Polarizer? Is it the entire thick film (about 0.5~0.7mm) above the glass or is there another film above this thick film ?
Please refer to the pictures attached. Regards
Offline george.b
  • Country: br
« Reply #6 on: October 19, 2020, 01:25:07 pm »
The polarizer film is the entire outermost layer. It's about the same thickness as an overhead projector transparency. The surface you're left with for replacing the polarizer should be bare, clean glass.
You'll probably have to do this to both sides of the LCD panel.
  • Country: sg
« Reply #7 on: October 19, 2020, 01:42:22 pm »
Thanks for the reply @george.b. It is a little thicker than the OHP transparency sheet, that's why I was a bit reluctant to pull it out. Secondly, I saw there was a small bubble at the centre of the screen (with the old polarizer still on it). When I touched this bubble, got some liquid on my fingers with the smell of Nail Paint. Does it imply the LCD screen crack and the pneumatic LCD liquid spill out ? Regards.
Offline george.b
  • Country: br
« Reply #8 on: October 19, 2020, 02:42:07 pm »
It's probably moisture and old polarizer goo. Like I said before, dead polarizers stink ;D
The LC fluid is sandwiched between the glass sheets, which are rather thick. See attached pic. Liquid crystal doesn't smell particularly pungent IMO.
« Reply #9 on: October 19, 2020, 08:22:44 pm »
I didn't need to replace the back polariser on mine.
Maybe I should have done to adapt to the new front one but the original back one hadn't degraded so I left it alone.
  • Country: sg
« Reply #10 on: October 20, 2020, 05:03:24 am »
Thank you, @george.b and @shakalnokturn for your valuable inputs. I managed to pull out the Polarizer from the front surface successfully. It took quite a work to pull out the film and clean up the residual glue from the glass  |O. Luckily no cracks on the glass. Yes, as mentioned by George.B, I will have to replace the Polarizer from the back end too as it is also seen to be cracked. Will post the update.
  • Country: sg
« Reply #11 on: October 27, 2020, 12:01:46 pm »
Mission Accomplished  :-DD
Today received the Polariser. Repalced both the front and the back polarisers and Voila !!!!! The results were amazing. Please see the attached Before and After pictures.
Thank you @george.b and @shakalnokturn for your support and timely help.
In the entire process, the residual glue cleaning was the most time consuming. Took almost 1 hour per side for the clean up. Used Nail Polish remover to soften the glue. Then scrap off using a sharp razor blade. Clean up the glass with IPA.
Offline george.b
  • Country: br
« Reply #12 on: October 27, 2020, 02:03:42 pm »
Well done! :-+
Always nice to see these scopes get a new lease on life :)
Yep, that's pretty much how it went for me, too. Would be nice if there was a more efficient (yet safe) solvent.
Offline CharlieD
  • Country: cu
« Reply #13 on: January 07, 2024, 09:07:23 pm »
Nice Work :-+
What polarizer film you used? Was the one provided by shakalnokturn in the link of the reply #1, or another?
I'm going to try the same with a TDS220 and want to be sure to order the right one.
Thanks in advance.
« Last Edit: January 07, 2024, 09:15:47 pm by CharlieD »
« Reply #14 on: January 08, 2024, 12:12:58 am »
If you look at the reviews on the 3DLens product page one is:
"Repaired a Tektronix TDS210 display
Mike - California, USA -
Worked, a bit lighter than original. I may try two layers on each side."
Offline CharlieD
  • Country: cu
« Reply #15 on: January 09, 2024, 05:08:06 pm »
Thanks.
I have noticed in some forum posts, and in several YouTube tutorials, that almost always when changing the polarizing filter on an oscilloscope or test equipment, the screen acquires a yellow/orange color, I would like to investigate more about this and How can it be amended?
