Author Topic: Repair Documents and Links  (Read 383435 times)
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
Re: Repair Documents and Links
« Reply #75 on: August 07, 2018, 04:33:01 pm »
I have gone through every website listed here and more. Any help is appreciated!
https://elektrotanya.com/bk-precision_1590a_parts_sch.pdf/download.html
You need to allow scripting for elektrotanya.com (if using noScript or similar) and wait for about a minute until the download link appears on the bottom of the page. Download is a 33.2 Mb .pdf file. The server is a bit slowish but who is judging free cake? :)
Kind regards,
Frederik
He’s like a trained ape. Without the training.
Offline tautechTopic starter
« Reply #76 on: August 25, 2018, 04:20:32 am »
Another spotted from a thread:
https://www.servicemanuals.net/service.aspx
Offline fzabkar
« Reply #77 on: January 04, 2019, 08:45:42 pm »
Here is a way to locate service manuals on Sony's web site:
https://badcaps.net/forum/showthread.php?p=588255
I haven't checked whether the method still works.
Offline Dmaumau
  • Country: br
« Reply #78 on: March 07, 2019, 01:36:19 pm »
Hello guys.
I´ve been searching high and low for the Yamaha RX-A3040 AV Receiver service manual and so far got squat.
Any leads ?
Thanks in advance.
The following users thanked this post: PD2AM
Offline Cliff Matthews
    • General Repair and Support
« Reply #79 on: April 14, 2019, 02:47:57 pm »
I'm going to post this here, since so little of repair on our forum touches (IMO) the invasion of electronics into heavy-duty appliances. YouTuber JohnAudioTech has a 14-minute close-up of how 6 IGBT's can find their way into a modern motor.
https://youtu.be/L7BA0333iII
Offline volvo_nut_v70
« Reply #80 on: August 15, 2019, 08:13:46 pm »
Found this interesting link, some manuals, mainly electronic books and...
« Reply #81 on: August 15, 2019, 08:14:33 pm »
Offline imaurente
  • Country: br
« Reply #82 on: August 27, 2019, 10:43:48 pm »
Does anyone have Amprobe 37XR-A Service Manual? Mine shows on the ERR display in almost every scale except the 10A scale and I've exhausted the possibilities for blind analysis.
Offline goaty
« Reply #83 on: December 13, 2019, 11:42:04 am »
Does anyone know what´s up with doc.xdevs.com ? Used it for information about 2400 SMU, but no connection now.
« Reply #84 on: December 13, 2019, 12:07:43 pm »
Perhaps under change at the moment. Give it a few days before doing a 'whois' discovery to send the admin an email..889020-0
Offline Shock
« Reply #85 on: December 13, 2019, 02:33:26 pm »
That is TiNs website (a forum member here). I sent him a message for you and provided him some extra info.
Offline Juup
« Reply #86 on: January 25, 2020, 09:58:24 pm »
On this Dutch website you can find many,many books also in English https://nvhrbiblio.nl/
Offline sean0118
« Reply #87 on: August 19, 2020, 11:29:12 am »
Hi all, just scanned an AWA datasheet that's in my collection.
It's for the AWM 1338 "48 Element Self Scanned Photo-Diode Array". It's quite an interesting chip, can't find anything about it on google:
AWA Integrated Circuit AWM 1338
« Last Edit: August 27, 2020, 11:23:12 am by sean0118 »
Offline sean0118
« Reply #88 on: August 27, 2020, 11:22:28 am »
I scanned some more AWA / AWV datasheets, searched a few and couldn't find them online. Hopefully they are helpful to someone.    ;)
AWA Low Noise Communication Type Transistors
AWV RF Power Transistors Featuring Overlay Construction
AWA Integrated Circuit AWM 1302 COMPLEMENTARY DATA LINE RECEIVER
AWA Integrated Circuit AWM 1301 COMPLEMENTARY DATA LINE DRIVER
AWA Integrated Circuit AWM 1269 FOUR BIT MEMORY
AWA Integrated Circuit AWM 1268 FOUR BIT MEMORY
AWA Integrated Circuit AWM 1272 LOW POWER AMPLIFIER OSCILLATOR-MIXER
AWA Integrated Circuit AWM 1306 LOW POWER F.M. I.F. AMPLIFIER DEMODULATOR
edit: scanned some more:
AWA AWM1269 FOUR-BIT MEMORY
AWA AWM1268 FOUR-BIT MEMORY
AWA AWM1250 AWM1251 DUAL FOUR-INPUT OR/NOR GATES
AWA AWM1278 AWM1280 RELAY DRIVER TTL-DTL/negative line
AWA AWM1270 WORD COMPARATOR
AWV AS200 AS201 NPN Silicon Planar Epitaxial Transistors
AWV AS303 AS304 AS305 AS306 AS307 AS308 NPN Planar Transistors
edit: some more (including RCA datasheets):
AWA AS204 AS208
AWA AS205 AS209
AWA Expandable Four Line Decoder Driver AWM1271
RCA General Purpose Transistor Arrays CA3018 CA3018A File No 338
RCA Optical Products Developmental Types TA7705 TA7787
RCA Special Function Sub System CA3044 CA3044VI File No 340
RCA Silicon NPN Over Transistor 2N5102 File No 279
RCA Low Power COS MOS Memory 16 Bit NDRO Type CD4005 CD4005D File No 348
edit:
AWV AS147
AWV AS128 Germanium PNP Alloy Transistor
AWV AS157 AS158 AS159
AWV AS300
AWV AS304 AS305 AS306 AS307 AS308
AWA Integrated Circuits AWM1250 AWM1251 AWM1268 AWM1269 AWM1270 AWM1271 AWM1293 AWM1308 AWM1309 AWM1278 AWM1301 AWM1302 AWM1281 AWM1306 AWM1311
AWV AS45 AS46 Characteristics At 25C
AWV AS205 AS209
AWV AS301 AS302
AWV AS148 AS149
AWV AS310 AS312
AWV AS204 AS208
AWV AS200 AS201 AS202 AS203
AWV AS311 AS313
AWV AS303
AWV AS200 AS201
AWV AS303 AS304 AS305 AS306 AS307 AS308 Characteristics At 25C
RCA HF Transistors 40235 40236 40237 40238 40239 40240
« Last Edit: January 29, 2021, 12:55:18 pm by sean0118 »
The following users thanked this post: AlfBaz, tautech, 4cx10000
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #89 on: November 24, 2020, 01:06:19 pm »
Hi I Have a lot of laptop service manuals for older models .But I don't have any where to load them up  to its about 8gb in zip form.and opened its aprox 1140 files using 9GB  all in PDFs.
Enclosed text index list of contents .So if some one has space on there site for some more manuals please let me know . Enjoy . :popcorn:
UPDATE:: I have loaded the Zip file to a Google Drive PM . Me for a link. Also I am loading about 80% of the PDFs up . which will be the 15GB limit.
  :popcorn:
« Last Edit: November 24, 2020, 06:37:31 pm by Labrat101 »
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
The following users thanked this post: jh15, Shock, tautech, sean0118, 4cx10000, Cliff Matthews
Offline Old Goat
Anadex FS-600 Frequency Synthesizer
« Reply #90 on: February 10, 2021, 04:47:26 pm »
I've searched this site (and many more referenced here), yet cannot find any data on an Anadex FS-600 frequency synthesizer. Actually, I find little to nothing on Anadex at all. So while I continue my search, might someone, anyone here have any docs on this gadget? It's VERY well built, but is off freq a bit and I can only walk it in to within about +15hz of "on freq".
And as always, thank you.
Don't Ever Say Never
Offline archil
  • Country: ge
« Reply #91 on: March 16, 2021, 08:55:23 am »
S-manuals.com  :-+
Offline JoeO
  • I admit to being deplorable
« Reply #92 on: April 30, 2021, 12:22:50 pm »
If the manufacturers link does not work, try to use the link at ARCHIVE.ORG.
I have found some information there.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #93 on: June 26, 2021, 11:44:51 pm »
« Last Edit: June 26, 2021, 11:46:43 pm by KG7AMV »
Offline Mick B
« Reply #94 on: December 10, 2021, 05:28:56 pm »
a dead link
Offline Labrat101
  • Regular
« Reply #95 on: December 10, 2021, 07:21:13 pm »
a dead link
At least say which Link is dead  :palm:
Offline Shock
« Reply #96 on: January 25, 2022, 11:48:24 am »
Free ebook on common pinouts.
https://pinouts.org/
The following users thanked this post: jh15, tautech
Offline Shock
Offline kickit2
« Reply #98 on: April 26, 2022, 01:47:16 am »
Looking everywhere, including every link posted here, and I can't find any service manuals / schematics for B&K Precision VSP12010.  Any ideas?
Offline icezebra
« Last Edit: November 13, 2023, 04:33:41 am by icezebra »
