Hi!
I have this type of inverter YEC 6038A0003301 for CCFL lamp from a bad laptop.
Does somebody know what is the voltage on the VDDP pin 16 of the MSC1691 ic?
Actually, I figured out the power connector pinouts for GND, VCC and PWR_on pins but I don't
have a clue what is the PWR_on and VCC voltage for this inverter.
I don't have the laptop so I cant check by measurement...
Here is a link about the IC but I'm not sure about the description because I translated it from CN to EN...
http://m.dzsc.com/data/html/2011-10-14/98866.htmlHere is the pinout and this is working well:
![](https://i.imgur.com/xsnh5Xf.jpg)
If somebody need...
Thank you very much.
My best regards.
