also for SMD did you consider pulse heat from pace? I got the resisttweeze (dual resistance heating elements in tweezer configuration) and they are pretty good for taking off 2 component SMD. The big soldering iron chop sticks are no doubt more precise but I think its a good tool even if the thermal control is a little simple in comparison. Looking to try the conductweeze (the direct resistance soldering) on some 4 pin solder cup power connectors for my nanovoltmeter soon... nice benefit for that tool if you also use the thermal wire stripper, its fast to heat up with the foot pedal.
But what I did is I setup a special repair bench with the pace extractor, pace pulse heat, a hakko fx888 and a old weller station + fluxes, solvents, deoxits, solders, etc.. I work down there now on any repair or assembly job, and its next to my tool boxes which have all the stuff for doing cables, glue, etc. and all the dust cleaning stuff (3 different kind of wipes, etc), and trays for screws..
I find it nice not to have the equipment or assembly jobs on my test bench anymore. I found that combining the two had little practical benefit for me. Since I setup the technician area I was able to service a ridiculous amount of equipment in the last season. I also did a generally better job like cleaner PCBs, nicer fixes, etc since the split. At least for simple devices that generally you know need alot of work, if its repairing intermittent issues in an oscilloscope you have something else completely.. the bench I have in mind is a little 'dull' intellectually but you get everything polished tightened cleaned reliable and so forth, even if the most complex problems are not solved, but that still gets you somewhere. Only things that missing is a sink with ultrasonic nearby (i still do this in the kitchen).. but once its setup well I can take panels out and take em to the garage for buffing or whatever I feel like doing to make it look great, without feeling too overwhelmed.. maybe you can call it a commercial restoration setup or something
but things like taking apart ganged switches on your main work bench? screw that!
Maybe call it a precision small scale electromechanical work area
