Helo guys.
The topic creator has moved on I imagine, but I am having the same problems with a Yamaha RX-A3040.
It started with a noise like a tv with no signal on the front channels and after a while progressed to all channels.
I still used it as a processor for a while, with an external amp, but the decided to run a firmware update to clean the software.
After that, it worked for a few seconds, turned off and now it only powers up with the protection bypass procedure.
It the shows these codes
DSP MARGIN
DC PRT 0000L
I´ll check tonite if there is really DC on the outputs, but reading the topic it seems that it might be a little bit difficult to debug than that, right ?
Until then, any educated guesses ?
Thank you very much for any and all help.
Mauricio
