Hello. My 5 years old kitchen hood suddenly stopped working, completely. There are two PCBs inside. Main one with transformer and relays. And second one with touch-sensitive buttons. On the power supply board i tested everything i could: capacitor, thermistor, relays, graetz connection etc. and it all measures good. Second one is full of small SMD components which i can not fully test. Connection between two PCBs is tested and fully working and connecting as it should.
Things that i noticed:
When i connect touch panel to power supply PCB, transformer starts to heat very much (can not be hold with hands), and voltage drops from 17.5V to 2.9V. Transformer is rated to 9V. Without any load and only connected to main PCB without touch panel/fan/lights measures 17.5V.
I did test with programmable DC PSU which i connected after graetz connection and when touch panel is disconected it measures no current but when i connect touch panel it reaches limit (draws more then 3A current). Here is video of my test:
https://youtube.com/shorts/r7lAetzZ0N4When i connect touch panel half-way and at angle LEDs starts to work, and at other angle fan is working but touch sensitive switches does not work.
When i power up switch PCB with my adjustable PSU it is short.
PS All connections and wire between touch panel and main panel are tested and they are good, so it is not bad plug.
Also, 4 of 6 (total) pins on switch panel are fully connected to each other.
Here are photos of both PCB
Thanks for your help.
