Author Topic: Racal-Dana 2101 Microwave Counter Repair  (Read 1879 times)
Offline TheDefpomTopic starter
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« on: March 12, 2021, 01:25:21 am »
I thought I would share this here, there doesn't seem to be many of these units around.
Cheers Scott
The following users thanked this post: doktor pyta, on4top
Offline on4top
Re: Racal-Dana 2101 Microwave Counter Repair
« Reply #1 on: March 12, 2021, 05:00:32 pm »
nice one !
Still struggle with mine after change caps ( 80% was really bad ) .
I use to have full service manual  in pdf .. can't  find it anymore :(
« Reply #2 on: March 12, 2021, 05:37:31 pm »
nice one !
The manual was hard to find, I had to purchase a Racal Dana collection CD from eBay to get it, but at least I now have a load of manuals !
I’m not home at the moment otherwise I would add others now, I did post it on my Patreon when I did the pre release video post.
Cheers Scott
Offline on4top
« Reply #3 on: March 12, 2021, 05:50:47 pm »
Have to check al my garbage harddrives .. must have it somewhere .
I think i got it from a yahoo groups member of the racal-dana group when it still existed . ( i bought the unit 3-4 years ago at Hamfest in Germany )
https://photos.app.goo.gl/G8kxvNwsqobnyRvq8
Some small hardware differences with yours .
« Last Edit: March 12, 2021, 05:55:30 pm by on4top »
Offline eevcandies
« Reply #4 on: March 13, 2021, 11:28:10 am »
If the keyapd goes bad an ALPS brand SKEGACA010 fits perfect, no lead bending, no stem adjustments, no nothing, just solder in.  However, the finished button height may be 1mm or so higher (barely noticeable, or not noticeable if you replace all the switches).  The caps fit only slightly snug, maybe even "good enough", but who wants to lose one ?? So add a drop of rubber cement & you will be in the winners circle.  This switch has recently been discontinued in 2021...so buy them while you can.   I bought 100 for $23 (& then another 100 more) from onlinecomponents.com (they are supposed to get more of them in stock). Arrow's pricing is next best.   https://www.mouser.com/datasheet/2/15/SKEG-1371040.pdf   Mouser prices is $$$.  Apparently the style is called a "joint stem" type, which may help in more searches.  https://www.eevblog.com/forum/repair/racal-repair-idea-quick!/
« Last Edit: March 13, 2021, 11:40:28 am by eevcandies »
Offline Andrejka
  • Country: lt
« Reply #5 on: November 15, 2021, 07:28:15 pm »
Hello,
Maybe someone can help me with Racal Dana 2101 counter GPIB board EPROM dump?
I have fitted GPIB board from model 1998, but does not work, different firmware.
Many Thanks
Andrej
Online factory
« Reply #6 on: November 15, 2021, 07:53:46 pm »
Someone has added the manuals to ko4bb;
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Racal/Racal_Dana_2101
Offline George Edmonds
« Reply #7 on: November 15, 2021, 08:09:43 pm »
Hi
For your information, The Racal-Dana support group still exists, it is at RacalDana@groups.io.
Owner/Moderator
