Author Topic: SOT-23 Device Marking Help  (Read 663 times)
Offline markmcnTopic starter
  • Country: ie
« on: July 24, 2020, 02:46:42 pm »
Hi All,
I'm hoping someone can help.
I'm working on repairing a SMPS,
I've hit a device which is in SOT-23 package which I'm struggling to identify.
Looking up the code gives me a few different devices depending on manufacturer.
Does anyone it's marked as "N2 C" but the is backward and more like a horse shoe. Photo included.
I'm hoping someone might be able to help identify the manufacturer so I can get a datasheet.
Thank you for the help and time.
Cheers
Mark
  • Country: ie
Re: SOT-23 Device Marking Help
« Reply #1 on: July 24, 2020, 06:12:13 pm »
So with some delicate desoldering work I managed to get it connected to a component analyser,
for any future reference this turned out to be an N-Channel Mosfet not sure who the manufacturer is I would still like to know who's logo that is but this datasheet seems to be close
http://www.s-manuals.com/pdf/datasheet/b/s/bsn20_r8-2_diodes.pdf
Offline fzabkar
« Reply #2 on: July 24, 2020, 07:44:48 pm »
It sometimes helps to identify other parts on the same PCB, just in case the designer has chosen the same manufacturer.
Offline kripton2035
« Reply #3 on: July 24, 2020, 08:44:11 pm »
could be a MGSF1N02LT1G
Offline thm_w
  • Non-expert
« Reply #4 on: July 24, 2020, 10:53:20 pm »
Few 20V FETs with the same code, for future reference google "SMD code list" and you'll see some sites/pdfs. Vishay or the ON one above look closest.
http://www.s-manuals.com/smd/n2
« Last Edit: July 24, 2020, 10:55:20 pm by thm_w »
