Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Pro Breeze® Air Purifier 5-in-1 with True HEPA Filter Repair
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Pro Breeze® Air Purifier 5-in-1 with True HEPA Filter Repair (Read 568 times)
csaszykj
Newbie
Country:
on:
July 17, 2022, 07:04:39 pm »
Hello
Could anybody help to repair my Air Purifier?
The Ionizer switches off the device after a minuter or so once it's switched on.
The Fan only part of the Purifier faultless, works as it should.
The manufacturer replaced the whole unit under warranty, and I don't want to throw away the "old one".
Also it has touch sensitive buttons.
Here are more detailed pictures:
https://imagizer.imageshack.com/img923/8939/r233L0.jpg
https://imagizer.imageshack.com/img924/1911/91EWMi.jpg
https://imagizer.imageshack.com/img922/3352/tLl5sz.jpg
https://imagizer.imageshack.com/img923/3690/iTgG94.jpg
https://imagizer.imageshack.com/img924/593/E6O50V.jpg
https://imagizer.imageshack.com/img924/3031/6yjDNG.jpg
https://imagizer.imageshack.com/img923/5782/Qao5SB.jpg
https://imagizer.imageshack.com/img924/7999/jW1sU0.jpg
https://imagizer.imageshack.com/img923/2654/SxDH6d.jpg
https://imagizer.imageshack.com/img922/2970/N4iCfw.jpg
Last Edit: July 17, 2022, 07:15:12 pm by csaszykj
Logged
wraper
Supporter
Country:
Re: Pro Breeze® Air Purifier 5-in-1 with True HEPA Filter Repair
Reply #1 on:
July 17, 2022, 07:08:36 pm »
This circuit apparently uses capacitive dropper, so check if the large yellow 1.5uF cap still has it's rated capacitance. Also be cautious as this circuit is directly connected to mains voltage.
Logged
csaszykj
csaszykj
Newbie
Country:
Reply #2 on:
July 17, 2022, 07:10:14 pm »
I've checked out with multimeter all the bigger parts, all the caps were empty/discharged.
Obviously I not gonna plug in while the PCB is "naked" in my hand.
Update:
- the large yellow :
https://imagizer.imageshack.com/img923/8751/YeuJY9.jpg
- the smaller yellow is start from high and slowly discharges
- the 3 other black cap - do i need to desolder them to get a good read? as I can't measure it
The back of the PCB has some shiny coating on, and as far as I can see - the Large Yellow cap has been replaced - as I can see flux residue on the joints.
Last Edit: July 17, 2022, 08:44:41 pm by csaszykj
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
