I blame @joeqsmith for this.
I dug out my old "Ham" transceiver and discovered it was having a TX issue. It started out by turning off the TX after a second or so. I verified I was not having a contact issue in the PTT button. Then it would stay in TX longer, but show high SWR on the indicator, even into a dummy load. The MOD/RF indicator is intermittent on sideband. A sloppy OTA spectrum view shows the carrier drops and presents multiple harmonics/spurs when modulated.
The notorious issue is with caps C75 and C60, 220uF electrolytics. These are connected to pin 7 of IC104, a dual package op-amp, which is just left of center.
http://w.datasheets.pl/telekomunikacja/cb_radio/cb/PRESIDENT-LINCOLN-5.PDFI measured C75 (I think the caps are connected in parallel anyway) and see 390uF, ESR 0.2, and 165R. I think the low resistance means they're bad but cannot tell what else is connected to that circuit. The few resistors I suspect are in the kohm range, but they didn't bother to indicate nodes on the schematic. I'd also expect the capacitance to be farther off.
I could just shotgun them and see, but that requires some more disassembly and would like to have greater confidence before heating the old board. Also, I have not found this failure mode associated with those caps, but I suppose anything is possible because it seems these shorting caps would load the entire 8V TX supply circuit.
What do you folks think?
