Author Topic: sc100 water circulator screen repair  (Read 460 times)
Offline rc100fTopic starter
« on: October 24, 2020, 05:27:04 pm »
Hello, I have a sc100 water circulator whose lcd screen is broken (more specifically the ribbon cable connection is broken). I dont think I would be able to repair it so I'm looking for a replacement. However it seems like it's an old obscure part from which the only reference I found is a datasheet from 2011 (http://www.believe.it/p.asp?p=YMC12864-286AAABDGL). So I was wondering if you guys would know of any other screen with a similar pinout.
Thanks for your help
Offline coromonadalix
Re: sc100 water circulator screen repair
« Reply #1 on: October 25, 2020, 01:36:29 am »
I think its this one instead, the other has a standard pinout, not a flex cable
http://www.believe.it/p.asp?p=YMC12864-286ACBBDGL
