You could check the connectors an solder joints, e.g. CN203 etc.
Thanks!
I will take a look at where the ribbon is soldered to the PSU board.
It is confusing to me how the PSU output is perfect until I plug the PSU into the rest of the machine.
I wondered if it was normal for those 5v lines to not appear, the schematic shows those four 5v lines all together.
That is confusing to me as well, if those points were bridged, I would not get respective 5v readings for each wire prior to connecting the PSU to motherboard..
Unless maybe the motherboard connection is at fault?
Thanks again!
