Hello,
I tried to repair a NAD T513 DVD/CD player that was showing "no disk error". Replacing the laser unit did not solved the problem.
I noticed that the LA6560 Five-Channel Driver was getting really hot but did not bother to replaced it so I gave the unit to a recycle center.
I kept the power supply for learning purpose but it is not working once removed from the player, I think it's because there is no load !
There is only one connector (15 pins)
1 VF+
2 VF-
3 -27VA
4 5.2VA
5 PWR_CTL
6 D.GND
7 5V
8 12V
9 A.GND
10 3.3V(1.8V)
11 3.3V
12 3.3V_M
13 D.GND
14 8V
15 M.GND
My questions are:
Do every power rail needs a load ? If so, which one and what king of load, just a resistor ?
What would you do to make it work outside the player ?
Thank you !
