Author Topic: Help Identifying component  (Read 485 times)
Offline JetbattalionTopic starter
« on: July 17, 2024, 09:35:04 pm »
I believe this is a mosfet. It is getting 5v in on pin2 and ground on pin5. Can anyone help me find the specs, or possibly a suitable replacement?
Offline wasedadoc
Re: Help Identifying component
« Reply #1 on: July 17, 2024, 09:38:04 pm »
D49 is written beside it. Why do you think it is a FET?
« Reply #2 on: July 17, 2024, 09:54:10 pm »
Thanks for the reply. I haven't seen very many diodes in that 6 pin sot23, but I know they are common. I don't have a good reason for believing it is a mosfet. It very well may be a diode, google results also assume that is what it is. I want to make sure I at least put one back that is close to spec
Offline wasedadoc
« Reply #3 on: July 17, 2024, 10:00:32 pm »
I would guess it is 3 diodes. Have you tried diode test 1-6, 2-5 and 3-4? (Power off of course.)
Offline fzabkar
« Reply #4 on: July 17, 2024, 10:01:10 pm »
TVS diode array for ESD protection?
https://www.alldatasheet.com/datasheet-pdf/pdf/523743/PANJIT/PJUSBLC6-2W6.html
USB 2.0?
The following users thanked this post: wraper
Offline Kurets
« Reply #5 on: July 17, 2024, 10:07:48 pm »
Yes, thats exactly what is is likely to be. The pins 1+6 and 3+4 are connected internally allowing you to pass through the device, ensuring that the shortest path to gnd/5V is through the clamping diodes.
Offline wasedadoc
« Reply #6 on: July 17, 2024, 10:08:17 pm »
USB 2.0?
That doesn't quite align with the second sentence of the opening post. Pin 1 is the one nearest the white dot on the PCB.
« Last Edit: July 17, 2024, 10:13:26 pm by wasedadoc »
Offline fzabkar
« Reply #7 on: July 17, 2024, 10:11:45 pm »
USB 2.0?
It does, if you rotate it 180 degrees. :-)
Edit:
It should be said that the device should work if the diode array is removed, albeit without ESD protection. You may need to bridge the inputs and outputs.
« Last Edit: July 17, 2024, 10:28:17 pm by fzabkar »
Offline RodentManiac
« Reply #8 on: July 18, 2024, 01:01:59 am »
My apologies, my coworker had submitted this question for me(my activation was stuck in spam limbo). Yes I had the pinout upside down. Pin 2 is ground, pin 5 is 5v. Does anyone by chance have a suggestion for replacement? The component is part of the camera circuit for a self cleaning vacuum, as well as a birthday present for the 19th. Any help is appreciated.
Offline fzabkar
« Reply #9 on: July 18, 2024, 01:30:28 am »
https://www.st.com/resource/en/datasheet/usblc6-2.pdf
« Last Edit: July 18, 2024, 01:49:44 am by fzabkar »
« Reply #10 on: July 18, 2024, 02:06:40 am »
Amazing help as always. It looks like that one isn't made anymore, but I believe the USBLC6-2SC6Y for the sot23 package is its successor. I will pick a few up. Thanks EVERYONE! You are amazing, and I owe each of you a cup of coffee.
Offline wraper
  • Country: lv
« Reply #11 on: July 18, 2024, 02:19:47 am »
^Nothing is obsolete. SC6 is packaging suffix, Y suffix is automotive qualified variant which you don't need. The regular part is USBLC6-2SC6.
« Last Edit: July 18, 2024, 02:21:35 am by wraper »
