I haven't been involved in electronics for donkey's years but I don't have the money
for a new hob and was hoping I could repair it.
Maybe someone can give a clue how to try to find the cause of the fault c3 .
I called Bosch and asked what c3 means as I couldn't find the fault code anywhere
and they told me it indicates overheating. I tried switching power off/on but it made no difference
(fault occurred again).
The PIE675T01E/09 hob has 4 plates: front and back left pair and front and back right pair and 3 pcb's , one
under each of the two pairs of plates and one in the front for the buttons.
The two plates on the left work without faults.
The two plates on the right work such that if you set them to a low heat value (max is 9, low is somewhere around 3), they almost immediately
start flashing the fault code. If you turn them on to a higher value, they will work for a few seconds and start flashing the fault code.
If you turn the hob off, you can again try setting the temperature and the fault occurs again.
I have opened the hob, disconnected the plates, thermistors and mains power, removed the right pcb
(I presume the right pcb is associated to the two right plates which cause the
fault code to appear) . It is a Siemens 9000 156 089 ELIN-DCHA ADV pcb. On initial inspection, I don't see any visible
damage anywhere except the mica on top of one of the two plates causing the fault has a slight haze on it (nothing
out of the ordinary).
All the 4 thermistors on the plates read some 60kohm and reduce in value when heated with hair dryer and return to this value
after some time. All of the plates read a fraction of an ohm.
So, I guess I'm "lucky" not to have an "easy" fault to find.
