Hi;
Just to share with you guys something that i came across today.
I received a faulty board from one of my clients. It has been installed and up and running for years. It uses a PIC16F628A. Among other things it has a HeartBeat Led and Uart communications.
Everything seems to work fine, only the uart was outputting garbage.
After checking the power supply directly to the power pins of the micro, i was measuring 7.7V. It was the 7805 regulator damaged.
I replaced the 7805 and the Uart start to work again. Of course i changed the Micro too do to over stress, but is remarkable, since the maximum absolute voltage is 5.5V according to datasheet.
Has anyone come across of a something like this?
