Well, you can try something like that. If you have mono signal, you need only one resistor. You may need to change the value of resistors to get desired sensitivity.
Sorry, I got it backwards, when LED is ON it means it is ON.
Ok, do you have voltages from power supply +24V, +12V, -12V?
Good. The problem is that STANDBY and MUTE is controlled by microprocessor and because you do not have active wireless connection, it turns off AMP.But you should be able to force the AMP to work by removing these resistors.
something like thissee the photos, instead of the fixed 10k ohms resistors you add this circuit
So you want volume control knob to be outside, like in this picture?If you do not want this, then it can be done with lower resistors on AUX IN, like 4.7K, 2.2K, 1K... Lower resistors will increase sound.
You have to do some small work on your side, you have to understand how potentiometers works and how to connect them.We have laid out the works for you ... all your answers was in the post i have made with the 3 pictures ...You have a beautiful tutorial here:https://www.doeeet.com/content/eee-components/passives/basic-principles-of-potentiometers-variable-resistors/
Well, something like that.
