Hello,
Have you purchased tools for repairing PCB vias where the core was accidentally pulled from the PCB?
I purchased a kit from Chip-Direct on ebay and was not able to get these tools to work properly.
Here are their directions for use
PCB Rivet Eyelet Tool / Pin
We ship this tools in a plastic tube for safe shipping.
Hit with a small hammer carefully on top of this pin. Take care for a hard underground !
Do not bend this tool when it’s in the rivet.
Always keep this tool strait up.
If do so, then you have a great tool.
Always place the rivets first on the PCB and then the components.
We have done some hundreds of rivets with this tools and have no problem at all.
Now it could just be me, but I had no luck with this. In fact, the rivets do not collapse as expected.
instead, the tool deforms.
What I believe causes this is that there is absolutely no chamfer to help guide the edge of the brass rivet outward to form a mushroom and then curl downward to the PCB surface.
(See illustration below)Instead the surface of the tool that contacts the rivet is completely flat.
it is possible that this tool will only work with special rivets....such as those having a pre formed outward mushroom shape on the tip of the rivet that should expand. However, such a pre shape seems as thought it might interfere with passing through the PCB in the first place. another possibility is that these brass rivets come in a varying degree of thickness such that thicker rivets are much harder to form into a mushroom and curl to the PCB surface?
The illustration below illustrates. The Flat tool (as supplied by Chip-Direct) will simply try to Crush the eyelet shaft straight down. This results in excessive force on the tool.
The proposed Curved tool on the right has a chamfer that helps the eyelet spread into a mushroom requiring less force and forming a nice circular contact patch to the PCB
If you have tried these tools what was your experience? Did I possibly receive a set that was not properly machined and lacked the chamfering ?
I do believe I used them carefully and as directed. have you tried them? What were your results? Can you suggest anything I did incorrectly?
Thanks
