Hello, I have a monitor (no name... the label on it was scratched) when sometimes at the opening shows vertical color thin lines.
First when I turn off and turn on the screen the lines dissapear or
Second if I leave open the screen after 3-5 minutes the lines gone.
I measured the voltages at the below tables when there are no lines displayed and when the lines are present and but all the voltages was the same.
I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed with any movement.
I brushed all the connectors with IPA.
Do you believe that these thin vertical lines it is from the degrade of the panel (new panel if I find) or from a bad component?
