Hi together,
does anyone know what part this BAO N10 ACE4506 is, maybe a transistor? I think it is an TO-252 package, but I couldn't figure out what it is.
It is located in the input area of an ACER LED Monitor. Input voltage is 19 V. The monitor only powers up if I warm up the area around this part and doing a power cycle.
The voltage between the lower left and lower right pin is around 2.4 V, but only under load.
