Author Topic: Panasonic WV-CP240 camera no image  (Read 1329 times)
Offline Puffie40Topic starter
  • Irregular Logic
« on: April 23, 2015, 04:40:06 pm »
I have been cleaning and testing some CCTV cameras and I have one camera (see title for model) that did work, but after a few power bumps due to a bad AC plug connection led to the camera failing to produce a image.
Upon a initial check of the power supply, I noticed a high-pitched hum coming from the board.  This leads me to suspect some capacitors are bad.
Is there any way for me to confirm this without pulling all the electrolytic caps?
