Author Topic: Panasonic DECT phone Base Station  (Read 367 times)
Offline tchoy668Topic starter
  • Country: sg
« on: January 09, 2023, 09:33:01 am »
I have a Phansonic KX-TG2512CX DECT phone system with 3 phone set.
recently the base station just generate the alarm call signal without anyone press on it.
how to resolve it, thank you
Offline MathWizard
Re: Panasonic DECT phone Base Station
« Reply #1 on: January 09, 2023, 05:34:25 pm »
So do you mean there's a button on the base station, that press to make the phone ring ?
If so you could try taking it apart and clean the button. There could be some bad voltage/noise on the button too.
Then there's way worse problems, like something going wrong inside some micro-controller or similar chip.
I haven't taken a cordless phone apart before, but I bet they are a nightmare of micro parts, and micro soldering. And IC's with phonebook sized manuals.
