Author Topic: Sanity check for a component on a receiver  (Read 519 times)
Offline n3vtiTopic starter
« on: October 12, 2021, 09:41:41 pm »
Hey guys, it's been forever since I've been here on this forum. (But that's a different story, different topic.) I'm doing a repair on an old stereo receiver. The part I'm looking for is a 50 Ohm, 1 Watt resistor, and unfortunately, I don't have one.  However, I do have 150 Ohm, 1/2 watt resistors. Could I use 3 of them in parallel (would give me the 50 ohms I need) and still get the same result? I can't remember if Power adds up in a parallel circuit, or if it stays the same. This is just more of a sanity check for me.
Thanks in Advance,
Chuck
Offline fzabkar
Re: Sanity check for a component on a receiver
« Reply #1 on: October 12, 2021, 09:46:11 pm »
That should be OK.
Each 150 ohm resistor passes a current of I/3, so the combined power dissipation of 3 resistors is ...
P = 3 x (I/3)^2 x 3R = 3 x I^2 / 9 x 3R = I^2 x R
where R is the resistance of the 50 ohm resistor and I is the total current.
« Last Edit: October 12, 2021, 09:52:56 pm by fzabkar »
« Reply #2 on: October 13, 2021, 12:08:58 am »
OK, that's what I thought. I kinda figured the substitution would work, but wanted to double check and confirm before I did anything. It's an old receiver (1975) and I don't wanna let the magic smoke out. :)
Offline mzacharias
« Reply #3 on: October 13, 2021, 12:21:12 am »
A 47 ohm resistor would be in spec - you could measure a few to get a little closer to 50.
It would make no difference in an audio circuit.
