Author Topic: Deciphering the worst manual ever: Ortec VT120 repair  (Read 945 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: April 09, 2021, 09:15:15 pm »
Hi! I've recently bought two Ortec VT120 "fast preamp" for channeltron timing experiments. I can't get them to work..
This is not necessarily the amplifier's fault, since they're 10-350 MHz bandwidth, and I don't think I have anything that produces rising edges that steep.
Either way, there's only 3 transistors in them, and no other semiconductor components, so I thought swapping them would be an easy attempt at a fix. The two shows the same characteristics with a slow pulse input: an output about half as big as the input; they're supposed to be 20x volatge gain.
now, the manual from Ortec: https://www.ortec-online.com/products/electronics/preamplifiers/vt120 is fine, but the resolution of the schematics.. jeez.
Can anyone tell the model numbers on the transistors?? I'm at a loss. See below.
Thanks in advance!
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
    • My channel:
Re: Deciphering the worst manual ever: Ortec VT120 repair
« Reply #1 on: April 09, 2021, 09:24:06 pm »
Oh, and the input clamping diode package as well! I think those might be bad. Could they be swapped for something like normal back to back 1n4148's?
They're BAV99's.
« Last Edit: April 09, 2021, 09:54:18 pm by ChristofferB »
    • My channel:
« Reply #2 on: April 09, 2021, 09:33:57 pm »
Here's a picture of the board, the right is input, left is output. I havent gotten much luck with the smd part numbers.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #3 on: April 09, 2021, 11:33:27 pm »
Well, I played with a bunch of transforms and maybe it's clearer. Best I could do is attached.
Does it look like the transistors begin with BF? I can make out some numbers. Maybe if you use that you can find something. I played with Irfanview to get that much.  :P
    • My channel:
« Reply #4 on: April 10, 2021, 12:58:59 am »
Thanks for your effort! Yes, BD or BF.. the rightmost one looks like it sais BD912, which does exist but is a TO220 power BJT.
Offline Messtechniker
« Reply #5 on: April 10, 2021, 05:13:28 am »
BF is most likely. BF transistors are commonly used in high frequency applications like this one.
A BF 812 does exist. Maybe 8 is being misread as 9.
« Last Edit: April 10, 2021, 05:15:58 am by Messtechniker »
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
Offline picburner
« Reply #6 on: April 10, 2021, 06:13:52 am »
Judging by the application and the SMD code they could be:
BFR93
BFR93
BSR12
I would definitely not replace the BAV99 with two 1N4148.
The following users thanked this post: ChristofferB
