If you buy a service manual, be careful!!!
There are two versions of the output stage.
My SMIQ03B (0.3MHz-3.300MHz) has three transistors in the output stage and it's an older model. The newer model has two transistors.
Of course, the difference is not just that.
The older model has a designation of the scheme 1084.9800.01 SA
New, all digits are the same, but only suffix S.
I'm throwaway money and hoping to have the correct schemes.
And what I bought is barely (scarce) visible! Almost unusable!
So I recommend that you look for a sample of a single sheet in PDF, before payment!
That's my experience
Good luck!
Aleksandar
