Author Topic: Motherboard no Image  (Read 731 times)
Offline 2XTopic starter
  • Country: gr
« on: August 01, 2023, 05:02:18 am »
Hello,
I have the below problem. I open the PC and it starts (CPU fan is working) but I have no image at all (not from the external VGA and neither from the on board VGA). Near to the bios chip there was some blown capacitors so I supose that something was happend with the voltage of the bios chip and the bios program corrupted or am I totally wrong? I replaced the "1" CPU with the "2" CPU and no image again. Also, I measured the CPU supply cable and it has 11,8Volt, but the strange thing is that both CPUs "1" & "2" are absolutely cold and the CPU fan spins (also the VGA chip is cold). All these symptoms are not bios (I can't find this bios... does anyone have it?)?
« Last Edit: April 19, 2024, 10:49:46 pm by 2X »
Online coromonadalix
Re: Motherboard no Image
« Reply #1 on: August 01, 2023, 11:03:00 am »
1st  give us the motherboard specs model number ...
do you connect all the power supply lines,  at least you need 2 connectors  1 for the cpu the other for the board ...
is your psu okay ?
  • Country: gr
« Reply #2 on: August 01, 2023, 05:10:29 pm »
I measured on the motherboard 3,3V, 5V, 1,2V, 12V. The motherboard there is from an ultrasound machine "GE voluson 730 expert".
https://i.machineryhost.com/a5b9b2898ac14fd01671e60936aa079b/large-gebraucht-ge-voluson-730-ultraschallgeraet-0394.jpg
« Last Edit: April 19, 2024, 10:49:58 pm by 2X »
Offline Vovk_Z
  • Country: ua
« Reply #3 on: August 01, 2023, 09:48:18 pm »
If you are lucky then yes.
But I don't see a bios chip on the MB photo at all.  |O
« Reply #4 on: August 01, 2023, 10:57:59 pm »
mmm they look like kontron 478 boards or ibase 478 .....
Kontron pcg820
seems a variant of this one ???  but the photo show  the bios socket on solder side ??
https://met8257.blogspot.com/2020/04/sbc-kontron-sbc-vga-single-lan-pcg820.html
http://mediaserver.voxtechnologies.com/FileCache/Kontron-PCG-820-D-1341847773S.pdf
welll
you had your answer already written on the pcb
TEAN TN2 94V0
now the Hard part is to find some bios ??  and conflicting infos,  some sites say socket 370 ??  and some the socket 478  ???
https://www.ebay.ie/itm/223644984142?
https://www.ebay.ie/itm/255981822001?
https://www.ebay.ie/itm/313961503070?
https://www.ebay.ie/itm/385139821903?
https://www.ebay.ca/itm/164288627254?
https://www.ebay.ca/itm/303698890084?
did not found anything but fakes links or else,   you may need to buy another one ????
« Last Edit: August 01, 2023, 11:34:04 pm by coromonadalix »
  • Country: gr
« Reply #5 on: August 02, 2023, 05:29:57 am »
Here you can see it. I upload wrond picture in my first post. I apologise.
« Last Edit: April 19, 2024, 10:50:14 pm by 2X »
