I recently forgot my sdr connected to a nearby antenna that had about 1kw to it and it seems the front end of my sdr is now dead. I can hear my HT on it, but none of the nearby stations come in, not even the weather. I assume that the transistor right at the RF connector is the culprit. I tried to identify the junctions, but only get a .7v drop across one set of pins. I want to try replacing this transistor, but I have no idea what it is. It is labeled "WAT 85". Does anyone have a clue what transistor that is or if I am even looking in the right area?
Thanks!
