Well, maybe !!
Since I don't have a second scope, I have to take the long road ....
I removed the sweep time and the vertical amp board once again to test every resistors and diodes with my DMM, something I did not do before. No open resistor found, maybe some's were out of spec but once removed they were good. No bad diode either.
I decide to look at the production changes for the 1472C and to my surprise not all the modifications has been done
Mod 1: was already done
Mod 2a: was already done
Mod 2b: was already done
Mod 2c: C139, C140, R222 and R223 by following the trace, not even there !!
Mod 3a: was already done
Mod 3b: was already done
Mod 3c: was already done
Mod 3d: It was indeed a 6.8K with no C248 ?? Replaced with a 4.7K and added C248
Mod 3e: C249 and L209 not even there !! I have to buy those parts.
Mod 3f: was already done
Mod 3g: D213 was missing ?? I added a 1N4148 from IC204 pin4 to pin12.
I put everything back together even if mod 2c and 3e are not done yet. Turned on the scope and now I have a pulse (max I saw was 318KHz) at P202 pin2 that varies when I rotate SWEEP TIME/CM, that's a small progress !!! When I adjust VR2, the voltage at P309 pin2 goes form +2.7V to +5.04V.
When I play with MODE (CHA, CHB, A&B, A+B, A-B) and VR2, I can see the intensity changes depending where MODE is.
I still don't have a pulse at pin 12 of IC202
That's all I can say for now
