I'm trying to get an old pre-CCD (vidicon tube) black-and-white CCTV camera working.
It's from about 1979 (GBC Mark XV). It worked when I put it away around 1982.
Now, no picture.
On an oscilloscope I see something vaguely like NTSC composite video (roughly 1v peak-to-peak). Except the base level (blanking level, lowest voltage of the signal) is around +4.5 volts. Line period is a little long - around 70 uS (should be 63.5). Front and back porch area of signal looks fine, as does vertical retrace.
When I wave a light bulb in front of the lens I see the signal level on each line (on the oscilloscope) move a tiny bit - barely noticeable.
This thing has a separate power supply box and a long cable with 9 wires in it. As best as I can tell:
Pin 1: Chassis ground
Pin 2: Can't tell. At 0v.
Pin 3: Seems to have something to do with audio. I can unplug it and still get the video signal.
Pin 4: Seems to have something to do with audio. I can unplug it and still get the video signal.
Pin 5: Video Ground (reference)
Pin 6: Video (composite NTSC)
Pin 7: +16 volts (from a transformer, full-wave bridge, and some filter caps)
Pin 8: Connected to a button on the camera (otherwise does nothing).
Pin 9: +12 volts (from a 7812 regulator in the box).
That's about all I know. There are about 10 pots in the thing, I twiddled all of them - only one seems to affect the output at all (seems to change the amount of noise in the output video signal).
Any suggestions re where to start?
