The meter in question has a blank display. Originally, the cable seemed damaged, so I hardwired the thing. I'm uncertain if I got my wires correct, if I damaged the display, or it's a problem with meter itself. I do have the service manual, and have confirmed as many things are working as I can. The only thing I can't see is the phase 2 clock, which comes from the MCU. Hopefully that doesn't mean bad. MCU, but I will debug that too. Every other pin on the thing seems right so far.
Anyway, I found a display ( hp 5061-5212) on ebay. Before I install it, I wanna do tests on the original to see if it works. The service manual explains the clock, sync, and serial data and instruction lines, but there are 16 lines going to the LCD, most of which I'm not sure what they do. I also have no idea what the instructions are, or the protocol used for instructions/data. Also, Whilst I can ID the known pins on the motherboard, I lost the original cable, so I don't for sure know how they map on the LCD end. Can't find another cable online, but would love to have one!
What I'm looking for is more info on the pinout of the lcd
