Yes, minimum load. Usually the underlying problem is compensation, where the output cannot be guaranteed no overshoot, over manufacturing and aging variances. During startup, or when a load is disconnected, the output voltage shoots up, and it'll just stay there if no load is present. It could also be that the controller oscillates in some way when lightly loaded. The load resistor bleeds away the excess voltage, and keeps the voltage closer to nominal.
