Attaching a picture of the relay that broke down (TEC 1226 735100), didn’t finds any similar so I started looking for the socket to find a relay that fits.
Is an unusual relay socket due to the coil connectors are not in line with the pins for the contact, the coil connectors is closer to the edge.
To temporarily get around the problem, cables are soldered from the old socket to a new relay.
